Engine Fan
Old 05-23-2007, 10:52 PM
95BOSS302
95BOSS302's Avatar
Default Engine Fan
I have a 1995 mustang gt and my fan finally burned out. I posted about a week ago about this but i have a different question. I have a temporary fan on for now and i just flushed the system and have straight coolant, not the 50/50 stuff and i am still over heating and i have the fan running all the time. what could it be?
95BOSS302 is offline
Old 05-23-2007, 10:56 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Engine Fan
Get rid of the straight a/f. It needs to be a 50/50 mix for better heat transfer. You may also have an air pocket in the system.
PRO50SC is offline
Old 05-23-2007, 11:03 PM
95BOSS302
95BOSS302's Avatar
If there was a air pocket in the system, then wouldn't it over quickly, because mine take about 15-20 minutes while driving to overheat
Old 05-23-2007, 11:06 PM
95BOSS302
95BOSS302's Avatar
Also does anyone know if the fan controls more than blowing air on the engine or does it control something else in the cooling system. I have a new one on the way
Old 05-23-2007, 11:16 PM
Yngvar
Yngvar's Avatar
I am running a 75/25 and it take forever to heat up when its cold out
Yngvar is offline
Old 05-24-2007, 08:37 PM
vt89gtvert
vt89gtvert's Avatar
To my knowledge, water provides better heat transfer then the glycol in A/F. The reason we run a 50/50 mix to help prevent freezing in winter (Thus businghoses and the like) and to help reduce corrosion. So by running a high or lower amount of water you are really hurting you motor in the long run.
vt89gtvert is offline
Nick Oliver
10-17-2018 04:22 AM
aznpersuasion
07-11-2018 06:40 PM
11-10-2015 11:39 AM
Pyrate Dave
09-10-2015 07:30 PM
09-03-2015 07:14 PM
Quick Reply: Engine Fan
