first thing to replace when over heating?
Old May 30, 2007 | 12:20 AM
tp65's Avatar
tp65
Default first thing to replace when over heating?
What would be the first thing to replace when over heating when a/c is cut on?
thanks
theo,
Old May 30, 2007 | 12:25 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: first thing to replace when over heating?
Actually overheating or just runing hotter?
Old May 30, 2007 | 12:26 AM
tp65's Avatar
tp65
oops.. yeah running hot. Sorry.
Old May 30, 2007 | 12:27 AM
tp65's Avatar
tp65
When i turn on the A/C it gets to the L in normal which makes me very uncomfortable.
Old May 30, 2007 | 12:28 AM
89 fox's Avatar
89 fox
1st...check your coolant level...if it is low...fill it up and pressure check it and look for leaks
PRO50SC's Avatar
PRO50SC
The Rogue Mod
By how much. It is normal for the engine to run a lil hotter than normal w/ the a/c on espesially on a hot day. If you're really concerned w/ it you could drop in a 180* stat.
Old May 30, 2007 | 12:29 AM
tp65's Avatar
tp65
ok thanks. Well if the coolant hasnt been changed in a while would that make it hot? I just got this car like a month ago.
Old May 30, 2007 | 12:30 AM
89 fox's Avatar
89 fox
also...if it went over 240*...change the thermostat
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Open the cap when it's cool and see what the radiator tubes inside look like. Also check to be sure the rad/condensor are free from debris
Old May 30, 2007 | 12:31 AM
85GTsleeper's Avatar
85GTsleeper
normal for it to run a little hotter with a/c
