suspension
i was thinking about getting this kit http://store.summitracing.com/partde...p;autoview=sku
it has FMS lowering springs .5" rear and .87" front Hotchkis Caster/Camber Plates and Strange shocks/struts for $675.95 but are the caster camber plates even necessary for that amount of drop? by purchasing the kit i would save about $100 give or take but the caster camber plates are like $230 for the pair.. i could get rear control arms for that but then i would be paying $100 more.. what are your opinions? |
RE: suspension
you wont be happy with those springs... they are a single rate spring and will ride VERY rough... all the time
RE: suspension
what kind of springs would you recomend for a softer ride? but i cant lower the car too much cuz my front wheels rub enough...[:@]
RE: suspension
RE: suspension
ur showing me the "deterioration in ride quality" ?
i would want progressive rate springs then right? my car drives like a tank right now n e ways lol |
RE: suspension
the M-5300-B (B springs) offer the same small drop as the C springs in that kit you posted, but are a progressive spring with will smooth out the ride, while still maintaining good handling characteristics
RE: suspension
alright cool thanx adder
but do you think that the caster/camber plates are necessary for that amount of drop? |
RE: suspension
nope, not at all
RE: suspension
adder i heard C/C plates where really only nececssary for cars with coil overs in the front... is that correct info???
RE: suspension
CC plates are only necessary if the alignment is too far out of spec and can't be adjusted with the stock equipment
thats all |
