flexplate problem
Old Jun 1, 2007 | 05:04 PM
86stanglx's Avatar
86stanglx
Default flexplate problem
i finally got the engine started but now its making a noise that it didnt make at first, it sounds like its coming from the front of the transmission where one of the flexplate weights was rubbing the engine backing plate, i pryed it away a lil and it is still making the noise. the local tranmission shop said to just grind a lil off the weight. does anyone have any suggestions?
Old Jun 1, 2007 | 05:12 PM
P Zero's Avatar
P Zero
Default RE: flexplate problem
You sure its on there right? And is the shield from an auto or manual car. I believe that theyre different.
-P.
Old Jun 1, 2007 | 05:21 PM
86stanglx's Avatar
86stanglx
the engine and transmission are out of the same car just rebilt
Old Jun 1, 2007 | 06:51 PM
86stanglx's Avatar
86stanglx
i was told today that i dont even need the dust sheild? thats is what i think is causing the problem anyways. do i need it
Old Jun 1, 2007 | 06:58 PM
P Zero's Avatar
P Zero
Its good to have just so crap doesnt fly up in there. And it does space the trans that much away from the engine. Is it rubbing on the little piece that bolts to the bottom of the bellhousing? Or is it somewhere else?
-P.
Old Jun 1, 2007 | 08:02 PM
86stanglx's Avatar
86stanglx
it seems to be rubbing up by the bottom of the block between the starter and the oil pan. im thinking of cutting that section out and see what happens then.
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
