Cleaning the TB???
Old Jan 1, 2005 | 04:51 PM
91hatchgt's Avatar
91hatchgt
Default Cleaning the TB???
Hello all, I was taking off my Air Induction, and I noticed a lot of build-up in the TB... I was wondering what I should use to clean it out... I was thinking about just spraying some carb cleaner in it.. Would that be okay? What do you all use?
Old Jan 1, 2005 | 04:55 PM
nemethjames1's Avatar
nemethjames1
Default RE: Cleaning the TB???
yup, carb cleaner, but its a good thing to use a brush of some sort and get a rag and wipe it out good... just sprayin carb cleaner on it wont do to much, stuff gets pretty caked on there
Old Jan 1, 2005 | 04:58 PM
91hatchgt's Avatar
91hatchgt
Yeah I knew that, was just wondering what substance to use... Thanks a lot.. Wanted to be sure before I sprayed something into my intake..
Old Jan 1, 2005 | 05:00 PM
nemethjames1
after your done, and you start it up, it should be a little hard to start, and it will smoke for a sec.... its just the carb cleaner burning off
Old Jan 1, 2005 | 05:01 PM
91hatchgt's Avatar
91hatchgt
cool thanks for the heads up... appreciate it
Old Jan 1, 2005 | 05:06 PM
Quik's Avatar
Quik
do your IAC also. i actually cleaned mine with oven cleaner. sprayed it on wiped it off
Old Jan 1, 2005 | 05:50 PM
vfast's Avatar
vfast
I ♥ Acer
I use brake cleaner ..as is has lil residue
Old Jan 1, 2005 | 06:55 PM
mstng675l's Avatar
mstng675l
well you could just get a new one..lol..just had to say it bro...
Old Jan 1, 2005 | 07:39 PM
91GTFox111's Avatar
91GTFox111
I ♥ Acer
Is it your Stock TB ... get a new one off like e-bay if it is
Old Jan 1, 2005 | 07:42 PM
vfast's Avatar
vfast
I ♥ Acer
65mm fms ones are dirt cheap
