hows my setup?
Old Jun 8, 2007 | 11:59 PM
jperz89lx's Avatar
jperz89lx
Default hows my setup?
hey guys, new to the site, just wanted to know what you guys think of my setup,it just feels like its not pulling as hard as it should...but here it is...stock block, and rotating assm., e-303 cam., shorty equal length headers, holley systemax upper and lower, #24 injectors, 70mm TB, 90mm maf, cai, and 3.73 gears...simple bolt on so far, but it still feels ehhh ok...but yeah thoughts, feelings, opinons w/e feedback would be great, thanks again
Old Jun 9, 2007 | 12:29 AM
945LSTANG's Avatar
945LSTANG
Default RE: hows my setup?
the stock heads r what is slowing u down. u already have a cam and intake....just need the heads. Upgrade and u wont be disappointed.
Old Jun 9, 2007 | 12:36 AM
nitrous_bob's Avatar
nitrous_bob
yup, you need heads or nitrous. (or both)
you really can't go by feel, get it to the track. look for about 100-102 trap speeds
the 3.73 is holding you back a bit too, 4.10's are optimal , but not worth the swap for 1 set
Old Jun 9, 2007 | 12:57 AM
immr.mustang's Avatar
immr.mustang
give that thing some heads and hang on!!!!
Old Jun 9, 2007 | 01:19 AM
94StinkinLincoln's Avatar
94StinkinLincoln
that 90mm maf is kinda big aint it?
Old Jun 9, 2007 | 03:29 AM
jperz89lx's Avatar
jperz89lx
what heads would go good with my cam?
Old Jun 9, 2007 | 04:05 AM
stang8689's Avatar
stang8689
you don't need the 24's either, not till head swap, did you upgrade the fuel pump, 90 mass air is huge not needed unless big turbo of supercharger
Old Jun 9, 2007 | 10:13 AM
dman302's Avatar
dman302
the cam is likely hurting your bottom end with the stock heads and valve springs, injectors likely pushing you into being a bit fat as well...combined you are likely finding power is down simply because the combo is not well matched to make power. Best bet is first return to the stock injectors and corresponding meter to see if the car runs a bit stronger.
PullTab
Oct 30, 2015 08:46 AM
uberstang1
Sep 20, 2015 06:42 PM
kevsgt
Sep 9, 2015 06:20 AM
JoshyGT
Sep 7, 2015 02:04 PM
