Compression test
Old Jun 11, 2007 | 11:43 PM
Foxbodyforever's Avatar
Foxbodyforever
Default Compression test
I want to do a compression test tomorrow at school, just need to know how to disable the fuel system and if there's anything else i should do beofre testing? thanks
Old Jun 11, 2007 | 11:52 PM
mattdel's Avatar
mattdel
Default RE: Compression test
take the coil wire off the coil and ground it somewhere, and disconnect the fuel pump relay, or trip the inertia switch
Old Jun 12, 2007 | 01:07 AM
Foxbodyforever
lol sorry how exactly do you disconnect the fuel pump relay?
Old Jun 12, 2007 | 01:14 AM
Mustangkiler's Avatar
Mustangkiler
Should just be able to unplug the power to the fuel pump in the trunk on the drivers side might be have to remove a cover over it.Mine has a big red button up top and i just unplug it from below the red button.
Old Jun 12, 2007 | 03:44 AM
tom29's Avatar
tom29
where is the inertia switch? and what would happen if u unplugged coil and didnt ground it, just left it hanging?
Old Jun 12, 2007 | 03:49 AM
mattdel's Avatar
mattdel
if you leave the coil wire hanging close enough, the spark can jump to it. if you ground it, a good distance away, it wont.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
