Which ratio is better for T5 tranny?
Old Jun 14, 2007 | 10:20 PM
Pony 5.0's Avatar
Pony 5.0
Default Which ratio is better for T5 tranny?
Does anyone know the difference in drivability between a 3.35 and a 2.95 first gear ratio T5 transmission?
Old Jun 14, 2007 | 10:37 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: Which ratio is better for T5 tranny?
3.35 will accelarate faster.
Old Jun 14, 2007 | 10:39 PM
raven_ghostwolf's Avatar
raven_ghostwolf
According to your sig you have 3:55 rear gears you would be better off with the 2:95 first gear set. My brother had a 3:35+3:55 set up in his old 90 vert and it was too low, first was about useless and 2nd was too short. I have the 3:35 with 2:73 in my 87 they work well. I plan on putting 3:27 rear gear in mine (depending what happens with the insurance after I got hit last night) 3:35+ 3:27 is about the same as 2:95 + 3:55 1st & 2nd gear once you hit 3rd the 3:55 rear end should be quicker!
Old Jun 14, 2007 | 10:53 PM
ZachW04Stang
I have a 3.35 first and 4.10 gears and its definitly quick but it gets the car down the track as fast as possible.
If you want more mild manored street driving definitly go with the 2.95 but if you want a little more push you back in your seat action go with the 3.35
Old Jun 15, 2007 | 01:28 AM
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
if its a stripe car 3.35 would be best... if its a street only car 3.35 might be hell to drive around in bad traffic.... u have 3.55 so id go with a 3.35 with a drag car and 2.95 with a street car... thats just my opionion tho... if u can handle really short gears ten get teh 3.35...
Old Jun 15, 2007 | 02:33 AM
dimebag's Avatar
dimebag
im not a fan at all of the 2.95 1st.... 3.55 ftw.... i have multiple reasons
Old Jun 15, 2007 | 03:33 AM
86 5.0L's Avatar
86 5.0L
ORIGINAL: dimebag
do tell.....
Old Jun 15, 2007 | 03:53 AM
dimebag's Avatar
dimebag
well, all i care about is drag racing, i could care less about having a longer 1st.... right now i have 3.08s and a 3.35 1st, imo, i want it shorter....
friend has a 2.95 1st... and 3.73s, it ****s up where he has to shift at in the 1/4.... where as w. 3.35 1st itll put ya right round 5500 in 5th(yes i plan to gety 3.73s)
Old Jun 15, 2007 | 04:45 AM
Tberg725's Avatar
Tberg725
i got 3.35 1st and 373's it scoots pretty good =)
Old Jun 15, 2007 | 04:48 AM
86 5.0L's Avatar
86 5.0L
ORIGINAL: dimebag
thought so....
