WHITTY TUNERS NEEDED!!!!!!
Old Jun 18, 2007 | 11:45 PM
cobrakiller306's Avatar
cobrakiller306
Default WHITTY TUNERS NEEDED!!!!!!
Alright guys, I'm in the process of tuner my car, and i just got er running last weekend, ran decent, but still crappy, so i put on maybe 15 miles on er to check the plugs, and it was rich, so in the process of checking things, i found a vacum leak, fixed it, checked the timing, it was retarded 5 degrees from where i set it at 15, so retimed it, and i have a ford racing computer, the one that piggybacks the stock computer, and reset the a/f ratio at i believe 11.5 to one, i'm not sure right now, and it ran really good, a problem i had was it wouldn't pull any r's past 5,500, it was like it had a rev limiter on it, then i did all that, and it pulled like it should, it was really a lot better, so driving it home, like 10 miles later, i kicked her down to 4th and got on it, and the best way to describe it is like it was out of gas, when i step on it in any gear , and it pulls like 500 r's and completly fulls on its face like no fuel, it wasn't doing that for like 10 miles when i did all the changes, what could possibly cause this, to act up later, ? the car was warm already when i ran good , so it's not like it got hot and changed?? help me out pleaz
Old Jun 18, 2007 | 11:57 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: WHITTY TUNERS NEEDED!!!!!!
sounds to me like you need to let someone who knows what they are doing, tune your car
Old Jun 19, 2007 | 12:48 AM
302f150's Avatar
302f150
eectuning.org and if ur using twEECer then your really set
Old Jun 19, 2007 | 04:56 AM
TTGreenSN95's Avatar
TTGreenSN95
do you have the stock H pipe on it sounds like a converter is plugged they get hot and wont pass any exhuast thru them....are you using the epec?
Old Jun 19, 2007 | 07:49 AM
uedlose's Avatar
uedlose
Are you using the extender if you are what do you have the rpm set at on it it has RPM and A/F . Good luck with it I had one years ago that did same thing in my car I put it in 3 other cars and it worked fine I messed with that thing for weeks on end never did get it so I sold it. Now I got a EPEC.
Old Jun 19, 2007 | 02:33 PM
jasonvri's Avatar
jasonvri
I ♥ Acer
ORIGINAL: cobrakiller306
I am worried about why the timing would change in such a short time...
How do you know where your afr is? WB O2?
lack of power can be many things.
Start by pulling the codes...
jason
Old Jun 19, 2007 | 03:04 PM
mattdel's Avatar
mattdel
fuel tank baffle
Old Jun 20, 2007 | 03:48 PM
cobrakiller306
I don't have a stock h-pipe, the timing changed cuz it was timed with a vacum leak, once i fixed it, checked timing and it was 5 degrees off, so that was fixed, I have the rpm at like 7000, i have the msd set to 6800 rpm, I messed with it last night, swapped plugs, and it didn't do anything wierd, still runnin rich yet, but the falling on it's face didn't happen, not exactly sure whats goin on yet, still workin on it
Thrashard340
Oct 15, 2015 11:05 AM
cedarmn
Aug 28, 2015 09:51 PM
Jacob4589
Aug 17, 2015 09:34 PM
defarmer
Aug 13, 2015 06:40 AM
Darrens07GT
Aug 10, 2015 03:59 PM
