injectors?
Old Jun 19, 2007 | 03:39 PM
Idrum88's Avatar
Idrum88
Default injectors?
will i need bigger fuel injectors with a H/C/I setup?
Old Jun 19, 2007 | 03:49 PM
LTnone's Avatar
LTnone
Default RE: injectors?
Depends... what h/c/i
Old Jun 19, 2007 | 04:02 PM
7upedition's Avatar
7upedition
^ werd... it may not hurt if you got the cash.. it'll give you some duty cycle breathing room until you s/c that beotch!
Old Jun 19, 2007 | 08:06 PM
Idrum88's Avatar
Idrum88
ill most likely get an e cam but i dont know what heads yet....but i am ordering a MAF for the stock 19lb injectors....and i dont want to have to get another one later if i have to get bigger injectors
Old Jun 19, 2007 | 08:11 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
then hold off on the maf unless it's a c/L one
Idrum88's Avatar
Idrum88
so i will need bigger injectors??
Old Jun 19, 2007 | 08:18 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
19's will work with what you have and that e-cam
Old Jun 19, 2007 | 09:09 PM
Idrum88's Avatar
Idrum88
ORIGINAL: 2 kwik
but will 19s work with the full H/C/I setup?
Old Jun 19, 2007 | 09:15 PM
white93pony's Avatar
white93pony
your gonna be cutting it close im running gt-40x heads f cam ona stock short block and had to put 24s in 19s cam only support 350 at 100% duty cycle and you only want to run a max of 80 at all times so it just depends on how much power you plan on puttin down.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
