AC problems
Old Jun 21, 2007 | 01:25 PM
Ryan5.0's Avatar
Ryan5.0
Default AC problems
My air conditioner is not cooling as well as it did last summer. It is cooling, but the compressor is cycling on and off every 2 seconds and the air is not as cold as it used to be. Could low refrigerant cause this issue, or does it sound like the compressor is screwed? Thanks in advance for any input.
Old Jun 21, 2007 | 02:00 PM
Blckstng93's Avatar
Blckstng93
Default RE: AC problems
Its clutch might be bad. or the switch. Dont know, havent had my a/c working for the last couple years.
Old Jun 21, 2007 | 02:48 PM
TwotoneVert's Avatar
TwotoneVert
You may just be low on freon, if so the , the low pressure switch will cycle the compressor off. If it is cycling, it should be good. Just put a can or two in and see what happens. If you have the converison to 134a, you can do it yourself, just stay on the low pressure side, the high pressure port could burst a can and cause injury.
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
