initial timing
Old Jan 8, 2005 | 11:29 PM
86gt5.0HO's Avatar
86gt5.0HO
Default initial timing
Hi, I've been reading the board for some time now after I purchased my 86 GT Cobra (with 5.0 HO). I was wondering what the initial timing is to be set at, and at what rpm? The guy before me painted over the stickeres under the hood. Also my idle is around 900 RPM how do I adjust the idle governer? Lastly, just out of curiosity, what HP and TQ figures does this engine put out?
Thanks
Rick Nagel
Old Jan 8, 2005 | 11:33 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: initial timing
10* initial is stock, thats set at idle with the spout connector unplugged. 14* is often run for performance reasons but that will require premium fuel. Idle can be adjusted by the idle screw on behind the throttle butterfly - doing so though would require you to re-calibrate your TPS. HP was around 205 I beleive, tq around 275. Maybe someone else knows the exact amount.
Old Jan 9, 2005 | 12:41 AM
Quik's Avatar
Quik
86 cobra??? never knew they made one unless yours is candian
Old Jan 9, 2005 | 02:30 AM
bobby's Avatar
bobby
you got a pic of it?
Old Jan 9, 2005 | 11:24 AM
vfast's Avatar
vfast
I ♥ Acer
they didn't til 93..on that car you can go with 14 degrees timing and use 89 octange
Old Jan 9, 2005 | 05:31 PM
86gt5.0HO's Avatar
86gt5.0HO
The car is Canadian. I live in Ontario Canada. I'll try to get a pic of it up soon.
mtgldr
Feb 3, 2024 09:00 PM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
