58cc or 61cc?
Old Jun 24, 2007 | 02:46 AM
thunderjet429's Avatar
thunderjet429
Default RE: 58cc or 61cc?
if it were me i would have the piston to valve clearance checked and then have the heads milled accordingly
Old Jun 24, 2007 | 02:48 AM
Mustangkiler's Avatar
Mustangkiler
58
Old Jun 24, 2007 | 02:51 AM
FullAuto's Avatar
FullAuto
58cc
If that makes the compression too high for you, adjust it witha head gasket. The 61cc is a different chamber design. It's not the same thing only 3cc larger. Buy the 58cc and work with it.
superman5.0's Avatar
superman5.0
sweet thanks alot guys. so just to review 165 58cc afr? that right?
Old Jun 24, 2007 | 02:52 AM
TwoToned306's Avatar
TwoToned306
I you have a low mileage block, then go with the 165's and spray.
It would save you the trouble of having them notched, plus have more power down low. They will also be better for that cam.
Old Jun 24, 2007 | 02:13 PM
backfire2007's Avatar
backfire2007
Ive heard that 58cc = more compression therefore recomended for natural aspirated.
as for 61cc = less compression therefore recomended for blower, turbo, or JUICE.
you need to do more research Imus
Old Jun 24, 2007 | 02:35 PM
my77stang's Avatar
my77stang
why not think outta the box and get something like canfield 170's? it puts you in the middle size wise and they are kickass heads that everybody and their momma dont have running around on their 5.oh's
170cc intake runners - 2.02/1.60 valves - 61cc CNC chambers - most .550 lift cams ok with stock pistons
CLICK ME
Old Jun 24, 2007 | 02:50 PM
OnyxCobra's Avatar
OnyxCobra
Just incase you're not aware the 58cc and 61cc heads use stud mount rockers so your stock ones will not work.
Old Jun 24, 2007 | 05:50 PM
ih8chevy's Avatar
ih8chevy
even wit a 100 shot i still think those heads would be a little much. people over look the capability of the 165's.
Old Jun 24, 2007 | 06:28 PM
AdderMk2's Avatar
AdderMk2
Banned
why do people settle for such slack *** parts???
Cobra Intake??? E303 Cam?? why bother changing it at all if your gonna use such POS parts
