Code 51 ECT open
Old Jun 26, 2007 | 04:59 PM
Pony 5.0's Avatar
Pony 5.0
Default Code 51 ECT open
Obviously I have a bad ECT.Pleaseindulge me with this one stupid question. Will this cause a slightly rich smell and exhaust popping? Thanks.
Old Jun 26, 2007 | 05:21 PM
Blckstng93's Avatar
Blckstng93
Default RE: Code 51 ECT open
A bad ECT affects the air/fuel mixture, timing, idle rpm, and emissions. Have you checked the connections for corrosion or a bad wire?
"If the ECT suddenly signals an infinite resistance as in an open, the control module ignores this input, which would otherwise drive the air/fuel ratio very rich. The FMEM switches to a fixed reisitance value for the ECT, allowing the warm engine to operate as a warm engine. At the same time the control moduel turns on the 'check engine' light. Do not expect a cold engine to start properly with a fixed warm signal for a cold engine. The FMEM is programmed to remember the ECT signal just before the failure and continue at that imput value."
This is known as a Failure Mode Effects Management (FMEM).
If youre still sure you need a new ECT get a new one and see if it fixes the issues youre having.
Old Jun 26, 2007 | 05:24 PM
Joel5.0's Avatar
Joel5.0
Yup....among other symptoms.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
