stud girdle
Old Jun 26, 2007 | 06:13 PM
1BIGMOFO's Avatar
1BIGMOFO
Default stud girdle
What exactly does this do for me and my roller rockers? Does this just support a little bit of stability? is it worth it? Thanks alot
Old Jun 26, 2007 | 06:17 PM
7upedition's Avatar
7upedition
Default RE: stud girdle
Pretty sure it minimizes the play in the studs, since they rest (without fastening) between the lifters and rocker arms, this keeps them from moving around too much, i would think they'd be worth getting, i assume they reduce wear and improve consitency in the stroke. Please correct me if i'm wrong...
Old Jun 26, 2007 | 06:58 PM
1BIGMOFO's Avatar
1BIGMOFO
sounds like you nailed it but if its not necessary to have is it worth the $180.00?
Old Jun 26, 2007 | 11:02 PM
1BIGMOFO's Avatar
1BIGMOFO
Old Jun 27, 2007 | 12:20 AM
stang8689's Avatar
stang8689
unless your putting out o ton of power, it will help them last longer but probably not needed
Old Jun 27, 2007 | 12:27 AM
Joel5.0's Avatar
Joel5.0
ORIGINAL: StrongStang50
$180 !!!!!.......... check these out ......it helps in strength and control in the valvetrain harmonics......your call though.
Old Jun 27, 2007 | 02:59 PM
luckythirteen13's Avatar
luckythirteen13
unless our running huge lift and/or really high spring pressure, i wouldnt waste the money
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
jjwinel78
Aug 17, 2015 03:34 PM
FD725
Aug 11, 2015 03:43 AM
Kryckter
Jun 19, 2004 10:29 PM
