Roller Rockers
Old Jan 11, 2005 | 12:29 PM
kornfan_88's Avatar
kornfan_88
Default Roller Rockers
What should I go with on stock heads? 1.6 or 1.7? Also, will these clear stock valve covers?
Old Jan 11, 2005 | 12:43 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Roller Rockers
1.7 with the stock cam for more performance
Old Jan 11, 2005 | 01:48 PM
nemethjames1's Avatar
nemethjames1
1.7's for sure
Old Jan 11, 2005 | 02:45 PM
91hatchgt's Avatar
91hatchgt
Yes, either 1.70's or 1.72's... You won't be able to really tell the difference, but it does make some. And yes they will check out with the valve yo piston clearence. Will raise your Lift to about .475 with Stock cam.. That is what I am doing soon.
Old Jan 11, 2005 | 03:27 PM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
i think you would notice a difference. but, the bad thing with those rockers is they put a bigger strain on the cam and timing chain (if its all stock and high mileage). remember, longer rockers means like extending your arm out and trying to hold up a brick, the longer your arm is, the harder it is. essentially.
Old Jan 11, 2005 | 06:56 PM
vfast's Avatar
vfast
I ♥ Acer
are you serious
Old Jan 11, 2005 | 08:24 PM
kornfan_88's Avatar
kornfan_88
These will be put on at the same time as a new double roller timing chain and and an edelbrock #3722 cam (same specs as e-cam)....sorry i forgot to mention that....still go with 1.7's?
Old Jan 11, 2005 | 08:27 PM
Quik's Avatar
Quik
youll be close with the E cam with piston to valve clearence. with that cam and 1.7s or 1.72s your lift will be .528/.528 not the best for a stock heads without porting.. so go with 1.6s with your stockers
Old Jan 11, 2005 | 08:35 PM
bobby's Avatar
bobby
ORIGINAL: Dbeck002
Design RT
uh, i dont think so
Old Jan 11, 2005 | 08:57 PM
kornfan_88's Avatar
kornfan_88
ok, thanks. I had heard somewhere that I should go with 1.6's but just wanted to check before I order all this stuff.
