need some advice!!!
Old Jun 29, 2007 | 10:11 PM
1fast5.0's Avatar
1fast5.0
Default need some advice!!!
ok i have a 87 lx motor is rebuilt edelbrock heads.edlbrk upp/lower and a sc i keep having a problem with my lower intake front gasket its good for couple days and then it starts to leak right behind the dizzy this will be the third time i have had to chang gaskets in a month can someone please tell me what is going on?? also i have a problem with oil coming out the dip stick tube .
Old Jun 29, 2007 | 10:35 PM
bds95stang's Avatar
bds95stang
Default RE: need some advice!!!
when was the last time you changed your pcv valve?
Old Jun 29, 2007 | 11:31 PM
1fast5.0's Avatar
1fast5.0
last year.could that cause this to happen
Old Jun 29, 2007 | 11:35 PM
bds95stang's Avatar
bds95stang
sounds like your not realeasing the crank pressure that would be why oil is coming out of our dipstick tube and if there is too much pressure it will blow seals...could be a cheap solution
Old Jul 1, 2007 | 06:35 PM
1fast5.0's Avatar
1fast5.0
bump
Old Jul 1, 2007 | 06:44 PM
pro tint's Avatar
pro tint
ORIGINAL: bds95stang
What would cause a motor to not release the crank pressure?
Old Jul 1, 2007 | 07:04 PM
shawnk007's Avatar
shawnk007
A clogged pcv valve
Old Jul 1, 2007 | 07:21 PM
pro tint's Avatar
pro tint
Could a clogged PCV Valve cause a very loud whistle sound out of the air filter (intake)
Old Jul 1, 2007 | 07:26 PM
shawnk007's Avatar
shawnk007
Not sure of that. But, you would have excessive blowby. Undo your oil filler cap and place your hand over the hole. You shouldnt have any pressure blowing on your hand.
Old Jul 1, 2007 | 07:29 PM
Mustangkiler's Avatar
Mustangkiler
ya that sound is pressure building up next time u hear that shut the car off pop the hood and pull the pcv and u should hear all the pressure releasing.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
