using some oil
Old Jun 30, 2007 | 04:55 PM
945LSTANG's Avatar
945LSTANG
Default RE: using some oil
ORIGINAL: VigCS
ORIGINAL: 945LSTANG
you are supposed to break it in. you guys are asking for problems.
Actually, there isn't really a break in needed on a roller cam motor...if anything you'll want to go out and run the **** out of it to seat the piston rings. I'll get a link in a second.
ive heard the exact opposite. im curious now...please find and post that link.
Old Jun 30, 2007 | 05:05 PM
67mustang302's Avatar
67mustang302
Yeah, there are big break in problems with flat tappet cams, especially with today's oils not having the zinc and phosphorous additives they once did. Even then, break-in can be quick if it's done properly.The guy I work forhasbuilt flat tappet race engines that get a 10-20 minute break-in then go run continuously at 6,000rpm for a season or 2, and if anything fails it's usually not the cam. With a roller engine though, it's not an issue since there's virutally no friction between the cam and lifter
Old Jun 30, 2007 | 07:49 PM
94StinkinLincoln's Avatar
94StinkinLincoln
um going to run it like its always gonna be run, like a scalded dog. anyways i left the filter on the table to cut it open to see what was inside and my dad looked at it today. ( i changed the oil yesterday) he said the seal came off the old filter and stayed on the engine and caused a double seal and is making it leak. phew lol he said he had that happen to him once (and hes changed oil quite a few times lol) so im going to go fix it now.
btw if an engine (hydraulic roller) cant handle WOT within 100miles of startup, what makes you think it will be fine at 3000 miles? if its gonna break, its gonna break.
Old Jun 30, 2007 | 08:19 PM
67mustang302
So you had to rubber o-rings on the block? That's not uncommon, I always check the old filter I take off to make sure the seal came with it. And yeah, like you said, if it's gonna break, it's gonna break
Old Jun 30, 2007 | 08:26 PM
VigCS's Avatar
VigCS
ORIGINAL: 945LSTANG
ORIGINAL: VigCS
ORIGINAL: 945LSTANG
http://www.mototuneusa.com/break_in_secrets.htm
[align=center]
[/align]
Old Jun 30, 2007 | 08:38 PM
94StinkinLincoln
yup just pulled it...2 seals lol so i cleaned the new one and put it back on the filter, tightened her up and filled her up. now im goin to a party so ttyl.
Old Jul 1, 2007 | 02:41 AM
hellion_79's Avatar
hellion_79
Break that thing in properly man!
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
