Cam and headers?
Alright, well I bought a 5.0 that needed work (some of you may have seen it) and I'm probably going to keep it now that I have the means and ability to do so, but I don't really know a whole lot about them yet so I'm still learning. My question is: I'm looking for a new camshaft, and headers. Any of you guys have any pointers? As far as camshafts, I want something that gives mild-to-good performance, but doesn't require modification in other parts of the engine. Any ideas? The car is automatic at the moment, and in the future I will probably have it converted. I can't change that at the moment, though.
As far as headers, I just want something reliable that will bolt in there without having to do any modifications to the headers to get them to go in there and sit correctly. * I also need to clarify it's a 1988 Mustang GT. |
RE: Cam and headers?
Forget the cam and get heads.
That's a possibility, also.
Get some gears and some heads those are the biggest gains you can get with a 5.0 outside of a power adder.
that's what I've been told, but I think I'm going to have to replace the cam shaft, so instead of going and getting another stock one, I'd like to do it once, and do it right. Know what I mean?
I hear ya, well the cam depends on if you plan to supercharge make it a stroker use nitrous or what u plan on doing with the car really. Then i could and many others could give you a little bit better advice on the choice.
ORIGINAL: Mustangkiler Forget the cam and get heads. |
+1 on having to tear apart heads if you do a cam anyway.
