Emissions Inspection
Old Jul 18, 2007 | 03:22 PM
matthoffman22's Avatar
matthoffman22
Default Emissions Inspection
If I have an after market block, like the new boss block, will i fail an emissions inspection? I dont have to go under the sniffer. It is just a visual inspection.
Old Jul 18, 2007 | 03:40 PM
only90s's Avatar
only90s
Default RE: Emissions Inspection
ORIGINAL: matthoffman22
Need more info:
Where you live do you have to pass Emissions ever..ie...In MA we have to do it every other year.
Old Jul 18, 2007 | 03:45 PM
matthoffman22
I live in St.Louis, Mo. I dont ever have to get the sniffer test, just visual inspection as the law recently changed.
only90s's Avatar
only90s
Do you still have your cats and smog pump hooked up...if so..you should be OK....
Old Jul 18, 2007 | 03:53 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
i doubt that
A that block is illegal
B if it is the guy is smart enough to know it
Old Jul 18, 2007 | 04:42 PM
blwn93gt's Avatar
blwn93gt
I dont think you'll have any problems.
Old Jul 18, 2007 | 07:12 PM
945LSTANG's Avatar
945LSTANG
STL is sniffer bud.....no visual. that is if you pass. fail it and they pop your hood and look for everything.
Old Jul 19, 2007 | 02:15 PM
matthoffman22
StL law is changing thisSeptember 1stbub. Have you not heard? The right people got mad about heavy equipment or business trucks or somethingnot having to get the test and nowits changing from the gateway clean air emission program to the gateway clean air inspection program.The legislation reads like this. MO Senate Bill 583
It also requires only 1996 or newer vehicles to be tested and takes advantage of on board diagnostic technology to conduct the tests. The bill also adds exemptions for the four newest model year vehicles and for vehicles used to travel less than 12,000 miles in between inspections. The new emissions inspection process will improve customer service and reduce motorists’ burden.
My car is an 89 so I will only get a visual inspection, and I know a guy that inspects without even opening the hood so I think I will be good.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
mrappe
Sep 26, 2015 10:16 AM
mltdwn12
Sep 23, 2015 08:54 AM
rksnow1
Sep 14, 2015 08:46 PM
