RE: Brakes
I couldn't find Ford parts. *shrug* Oh well, thanks anyhow. You guys have all been such great help.
RE: Brakes
another idea is to do an sn 95 swap... how good are you at wrenching your own car??? are you racing the car?? lots of variables in determining what the right set up is for you. a little more info would def. help
RE: Brakes
ORIGINAL: Jeremiah I couldn't find Ford parts. *shrug* Oh well, thanks anyhow. You guys have all been such great help. you must have not clicked much of anything |
RE: Brakes
ORIGINAL: tripsevn7 another idea is to do an sn 95 swap... how good are you at wrenching your own car??? are you racing the car?? lots of variables in determining what the right set up is for you. a little more info would def. help @ Jasperstang308: Wow, I feel dumb. |
RE: Brakes
If money isn't a issue you could get a baer brake kit. Baer sells a kit that converts it to 5 lug, comes with 13" front rotors, 12" rear rotors,big cobra stylecalipers, baer proportioning valve, and steel braided brake lines. I got lucky when I bought my car it already had these brakes on it and they stop amazing. There's a couple picture of my brake's on my cardomain site
http://www.cardomain.com/ride/2563506 |
RE: Brakes
Price is going to be a bit of an issue unfortunately. Something $250 or under less is the approximate price range.
RE: Brakes
well... you won't find any conversion kits for that, but that maximum motorsports kit looks pretty good. i was thinking about getting that. well i will when it's time for new pads. and i've never heard anything bad about MM. other than that i don't know of much else out there... i mean you could get new rotors too. that are cross drilled or slotted. i have cross drilled ones and can't complain. but they were on there when i got the car, so i don't know how the stock ones are
RE: Brakes
ORIGINAL: Jeremiah Price is going to be a bit of an issue unfortunately. Something $250 or under less is the approximate price range. https://mustangforums.com/m_968156/tm.htm |
RE: Brakes
If you looking to change your brakes and is going to be a daily driver just get sum Bendix brake pads from napa.
