replacement for e-cam?
i dont really like that this thing has an e cam in it also. would i see a huge difference if i maybe swapped over to a comp extreme energy cam? im pretty sure those cams work quite well with the blowers.
Yes, seeing how the e-cam is for a slightly modded car for emissions reasons right? I was thinking about getting the e-cam, or maybe just some 1.72's on my stock cam, I want something to make it revv out more.
actually i was trying to get out of the ford alphabetical cams. but the f-cam would probly be better cause the e-cam is 2500-5500 rpm's. so the F would probly be a little higher in the rpm range since i take it with the blower to 6k
i was going with the f cam myself... still unsure now, but comp cams are a great choice... bit before you do anyting i would get on the phone with them and tell them your setup
If I had a choice, I would get the 1.72 rockers for the stock cam. A lot of people don't like their E cams when they get them.
There are much better choices in cams now a days instead of the alphabet cams.
