problem starting/running
Old Aug 4, 2007 | 12:33 PM
redneck racer's Avatar
redneck racer
Default problem starting/running
well last night i went to wal-mart, when i come back out and try to start the car, when i crank the car it will run, but when i let go of the ignition, so it returns to the spot it sits when running the car shuts off. I managed to hold the key halfway and drive home with 1 hand but i cant do this all the time. Is this the ignition switch itself? or is there a problem somewhere else because my positive cable from the battery also burnt up and im unsure if it damaged the cilaniod.
Old Aug 4, 2007 | 12:37 PM
mattdel's Avatar
mattdel
Default RE: problem starting/running
the ignition lock cylinder is bad. need a new one.
it will come with new keys, but you can bring it to a locksmith if you wish to maintain usage of your current key.
the wiring is probably because of the ignition, too.
Old Aug 4, 2007 | 01:49 PM
cleanfitty's Avatar
cleanfitty
ORIGINAL: mattdel
My money is on the actual electrical ignnition switch inside the column.I'd bet the lock cylinder is fine.
Old Aug 5, 2007 | 07:32 AM
redneck racer
ok, i want to replace replace both, how easy/hard would this be. Also, i always have trouble finding 83-85 parts, can anyone recoomend a place to get a new switch and cylinder.
Old Aug 5, 2007 | 10:01 AM
cleanfitty's Avatar
cleanfitty
http://www.latemodelrestoration.com/...1&comp=LRS
This should be it...
You can check w/ the dealer for a Motocraft or if not you can check with Napa.
Old Aug 5, 2007 | 10:14 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: cleanfitty
ORIGINAL: mattdel
I concur!
Old Aug 5, 2007 | 11:17 AM
stang8689's Avatar
stang8689
Pretty easy to install
Old Aug 5, 2007 | 11:32 AM
redneck racer
thanks fellas, hopfully ill be able to put them on myself.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
