bigger cam in a 86lx?
Old 08-09-2007, 02:02 PM
hondhunter
hondhunter's Avatar
Default bigger cam in a 86lx?
i was wondering if i could put a bigger cam in my 86 without hitting the valves to the pistons. whats the biggest i could get? e303?
hondhunter is offline
Old 08-09-2007, 02:39 PM
my77stang
my77stang's Avatar
Default RE: bigger cam in a 86lx?
you are aware you'll need stiffer springs for virtually any roller cam upgrade right? with your pistons your also limited in his big you can go. i dont know the exact answer, but i can tell you whatever it is you dont want to be throwing money at a frpp alphabet cam.
my77stang is offline
Old 08-09-2007, 03:09 PM
ih8chevy
ih8chevy's Avatar
i have seen trick flow stage 1 cams put in there fine on a stock 86 block. I believe the ptv is something like nothing bigger than .520 lift. But I could be wrong
ih8chevy is offline
Old 08-09-2007, 04:11 PM
ZachW04Stang
ZachW04Stang's Avatar
With an 86 there isn't much clearance even with the stock cam. If your trying to do a budget motor just buy a 87-95 shortblock and build on that.
ZachW04Stang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
junior04
09-28-2015 10:53 AM
Quick Reply: bigger cam in a 86lx?
