wtf will be next
ok so i finally get all the parts for my brakes get them on an now antifreeze is leaking from around the water pump dont know if it is pump or hose(how do u tell?) an when it will start it has a real bad idel(what would bad idel be from or why will it not start). any help would be much app. thanx
ORIGINAL: red94gt
If its leaking coolant around your water pump I'd be willing to bet big bucks your water pump is leaking from the weep hole. Look on the little hole on the bottom of the water pump. If it leaks your pump is shot. New water pumps arent too expensive.
Yea, I just had that same problem, my water pump was toast. I bought a new one for like $45. If your bolts aren't new or look really badI would really suggest buying some new ones, cause I tried to put my water pump back in last saturday, and a bolt snapped off in the block, now I got a whole lot more work to do instead of just the water pump because I used the old crappy corroded bolts. Someone gave me the part number to the bolts for autozone/schucks and it was 23744. The kit is only a set of 3 though. Do yourself a favor and buy new bolts for it so you don't have to go through what I have to now...
car only has 75,000 on it an what kind of wheel's r those on ur stang
