timing confermation
timing confermation
i tried to bumb my timing today i just want to be sure i did it right. when i pulled the pin and look at the timing numbers i saw the other line the other owner had it at and it was like 8 or something so i made a mark around 13-14 and changed it, when i put the in back in the timing moved up to 23-24. is that wats its supposed to do or am i going to blow my engine?
also i did this because some people thought it would sovle my intake backfire, the car right now runs smoother and feels stronger but i still get the intka e backfire.
im going to change ,y fuel filter now, my pump is ok, if that doesnt solve it im going to start looking at vaccuum leaks, although it looks fine.
RE: timing confermation
Yes, the timing will jump when that timing plug is back in.
As for the back firing, I still believe it is a vacuum problem. Double check the wires and firing order. I know you said it was right, but it doesn't hurt to check again.
update
i finished wokring on the car abour 2 hours ago just finished washing it for a car show tommorow.
i bumped the timing to about 14 or 24 with spout, the car ran better but i could tell it was a bit hesitent, i could feel more power as i was flooring it,.
i drove around my neighbour hood up to my uncles house and i floored it and boom there it was intake backfire so i knew i did fix it.
i got home and right away i changed the fuel filter whcih is the easiest thing to do, hardest part is taking out the dam clips. after i did that i went for a spin up to crappy tire for carb cleaner to check for vac leaks. the whole way i floored it going through all the gears tring to see if it would backfire again and it didnt.
got home reved the engine and it would not backfire so i think i got to the bottom of it, if it does it again ill let you guys know and we'll take it from there.
1 question through. my volt meter runs pretty high, its been the same since i started screwing with the car. it between the middle of the guage and the top of the guage. so about 3/4 of the way. is there a reason for this.
regulator might be going bad, but the gauge itself might not be the most accurate.
take your old filter and try to blow through it. make sure you don't inhale through it, just blow through it. it should be pretty free flowing.
if its not, you might have found your problem.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
