help!! knocking engine
Old Aug 16, 2007 | 07:36 AM
highskewlmustnglvr86's Avatar
Default help!! knocking engine
ok well i was driving my car and made it about 2 miles up the road when it backfired then started knocking.the weird thing is it only knocks when i give it gas, and it sounds like its in the top half of the engine...it is a very loud definite knock.does any one know what happened?
thanks tyler
Old Aug 16, 2007 | 07:40 AM
MikeVa's Avatar
MikeVa
Default RE: help!! knocking engine
How's the oil pressure, engine temp? Check the timing. Sounds like a HUGE vacuum leak occured causing it to lean out really bad leading to severe detonation. Check the simple stuff first: Timing, oil pressure, vacuum hoses, etc. Report what you find and we'll go from there.
Old Aug 16, 2007 | 08:11 AM
rashii12345's Avatar
rashii12345
yes check those
if those are fine i suggest taking the valve covers off and checking the rockerarms, thats what was wrong with my 95 2.8 when i got it
Old Aug 16, 2007 | 10:45 AM
Texas5.0's Avatar
Texas5.0
I would guess your timing is to high. Have you changed brands or grade ofgas recently?
Old Aug 16, 2007 | 03:15 PM
Twisted's Avatar
Twisted
If it happened suddenly, I'd guess a either a vacuum hose popped off or broke, or a part of your fuel system has clogged or failed. Any loud hissing from under the hood?
Nick Oliver
Oct 17, 2018 04:22 AM
degner122
Sep 16, 2015 07:09 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
