Tailipes
Old Aug 21, 2007 | 12:20 PM
86GreenMachine's Avatar
86GreenMachine
Default Tailipes
Is it possible to stick 3inch tailpipes on a fox???
Old Aug 21, 2007 | 12:41 PM
88_cobra's Avatar
88_cobra
Default RE: Tailipes
yes a friend of mine has them on his turbo notch, it sounds ungodly
Old Aug 21, 2007 | 12:56 PM
WhiteWindsor's Avatar
WhiteWindsor
Are you talking about the actual exhaust or just the tips because you don want 3in exhaust on a basically stock mustang, it could make it run bad because you will virtually have no backpressure. I run a 3in off road x-pipe but i havea need for it.
Old Aug 21, 2007 | 02:18 PM
86GreenMachine
so with stock exhaust and flows 3inch tailpipes wouldn't be good.What would id need to do so i can run 3inch tailpipes?
Old Aug 21, 2007 | 02:38 PM
WhiteWindsor
I guess i am confused. Do you mean you want to run 3 in pipes after the flowmasters. If that is the case that will no be a problem. I was assuming you had after market exhaust like headers, x or y pipe and you wanted to run a 3 in. x or y after the headers.
Old Aug 21, 2007 | 02:42 PM
86GreenMachine
Yep just the tailpipes i want to put 3 inch.So the backpressure should be fine.
Old Aug 21, 2007 | 03:06 PM
WhiteWindsor
Yea, it will be fine.
Old Aug 21, 2007 | 03:13 PM
86GreenMachine
Thanx
Old Aug 21, 2007 | 04:00 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
why waste the money..thier not cheap because 3" pipe is hard to bend and offers nothing but sounds
Old Aug 21, 2007 | 04:02 PM
86GreenMachine
i called the place where imgetting my exhaust fixed and they said its to tight and they dont want to waste there time .So 2 1/2 it is.[:@]
