steering wheel
Old Aug 21, 2007 | 04:38 PM
Streetracer911's Avatar
Streetracer911
Default steering wheel
Could anyone tell me why my steering wheel is shaking so much? It happens at like 50-60 km/h and just seems to get worse going faster. It is pretty annoying to drive with it like that. Any Ideas on how to fix it or tell me what I need to replace. I also find if I am making a turn I have to almost pull the steering wheel back, most cars the wheel goes back straight....so how do I fix these two problems? Thanks
Old Aug 21, 2007 | 05:11 PM
nseoi's Avatar
nseoi
Default RE: steering wheel
sounds like an issue with your power steering. check your fluid levels and the pump. other than that look at any possible steering rack damage
Old Aug 21, 2007 | 05:17 PM
mattdel's Avatar
mattdel
i'm bettin on bad tie rods, given the fact that you need to pull the wheel back to straight, its a toe issue as well.
Old Aug 21, 2007 | 05:44 PM
Boss_Hotrod's Avatar
Boss_Hotrod
The wheel not coming back is most likely a power steering issue. Try flushing the system first (might help). As far as the shakin goes that could be all kinds of stuff. Our 93 did that and I had to replace an inner tie rod, have the tires balanced, and replace the rotors and bearings (that helped the most). Just check everything and it wouldnt hurt balance the tires anyway since you're really supposed to do it every so often.
Old Aug 21, 2007 | 06:45 PM
Jfsram's Avatar
Jfsram
Check the front ball joints. They could be seizing up.
For the steering wheel shake. Start off with simple things. Have the tires balanced. Road force is the latest way to balance a tire. It can also recognize a bad sidewall or an assembly that's out of round. Old style balancers ONLY balance the tire/wheel. A tire/wheel can be balance but not be round.
If that's unsuccessful, try an pair of wheel/tire off another car on your front or just rotate your set up.
Old Aug 21, 2007 | 08:08 PM
WhiteWindsor's Avatar
WhiteWindsor
ORIGINAL: mattdel
Yes, check the tie rods. Jack car up and grab wheels at 9 and 3 and try to wiggle back and forth. If you have play that is probably your problem.
Old Aug 21, 2007 | 08:17 PM
Streetracer911
do you mean like left and right or like pull the tire and push it type thing?
Old Aug 21, 2007 | 08:22 PM
Boss_Hotrod
Pull on one side while pushing on the other then do the opposite.
Old Aug 21, 2007 | 08:34 PM
Streetracer911
and what should i be looking/feeling for? thanks for your help guys
Old Aug 22, 2007 | 06:14 AM
WhiteWindsor
Your are trying to see if you have any play, meaning does it move any.
