Compression Results
Old Aug 23, 2007 | 08:19 PM
gearbanger's Avatar
gearbanger
Default RE: Compression Results
ORIGINAL: tinman
I would, at this point check and see if someone installed a non-stock camshaft.
Readings like you got could be as a result of some extra duration in there, that will lower the readings of test.......
i got a e cam with one 1.7's... a after market cam would cause lower compression?
Old Aug 23, 2007 | 08:38 PM
HACKGT350's Avatar
HACKGT350
i just want to throw this out there if you didnt know when you do a compression test to get the best result take all the spark plugs out make sure the engine is hot. and when you crank it over put the gas to the floor to make sure the tb is open all the way. oh yeah make sure the coil wire is off too lol
Old Aug 23, 2007 | 08:40 PM
HACKGT350's Avatar
HACKGT350
ORIGINAL: gearbanger
ORIGINAL: tinman
sure would. you could get my valve over lap which brings your compression down.
Old Aug 23, 2007 | 10:12 PM
gearbanger's Avatar
gearbanger
ORIGINAL: HACKGT350
i took out all the spark plugs and the engine was warm but i didnt floor it...... because of the cam and rockers it gave a me alittle lower compression level which means.... my numbers are good?
Old Aug 24, 2007 | 06:59 AM
WhiteWindsor's Avatar
WhiteWindsor
ORIGINAL: tinman
I am not disagreeing, as you may have more experience than me. But in my 351, the cam has a duration of 246/259 @ .050, i cant remember adv. duration, but it is over 300, my compression numbers are all between 180-185, well, come to think of if it i also have 11.1 compression, so maybe that is why the high numbers.
Old Aug 24, 2007 | 09:42 AM
HACKGT350's Avatar
HACKGT350
ORIGINAL: HACKGT350
if you want to try it again put the pedle to the floor it should up the numbers a little bit getting more air in the chamber will give you a better compression. im still not sure how much valve over lap you have with that cam so that could do it too. the intake and the exhaust valve will stay open at the same time longer and you will lose some of the air coming in the intake valve and going right out the exhaust. the less valve over lap the higher the compression
Old Aug 24, 2007 | 01:44 PM
1BIGMOFO's Avatar
1BIGMOFO
yea, if you need the car to get all around, leave it alone. If you dont care throw a 125 shot to it and start saving for a rebuild
baddog671
Jul 26, 2016 01:20 PM
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Sep 24, 2015 09:18 PM
bconboy
Sep 21, 2015 12:52 PM
