smog pump delete ?'s
Old Aug 24, 2007 | 02:42 PM
notch5oh's Avatar
notch5oh
Default smog pump delete ?'s
i know youinstall the pulley and remove the rubber hoses that come off the pump, but what do you do about the metal tubes that attach to the hoses? Also is it ok to run a delete kiteven if i still have cats?
Old Aug 24, 2007 | 02:56 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: smog pump delete ?'s
you'll plug your cats, you need an OR h-pipe
the steel pipe that runs behind the heads can be removed and discarded, then you need to plug the back of the heads w/ thermactor plugs
the steel pipe that goes to the h-pipe can be cut off and capped
Old Aug 24, 2007 | 04:22 PM
notch5oh's Avatar
notch5oh
ORIGINAL: nitrous_bob
i probably should have asked this question before i bought the delete kit
Old Aug 25, 2007 | 12:12 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
why buy a delete kit you just get a 770k6 belt it keeps the stock routing and its only 15$
Old Aug 25, 2007 | 12:27 AM
OnyxCobra's Avatar
OnyxCobra
man, my short belt was like $40
Old Aug 25, 2007 | 07:39 AM
nitrous_bob
mine was $25 i think......dumping the pump and gear is a 20 lb weight cut off the front
Old Aug 25, 2007 | 07:58 AM
tmajikman's Avatar
tmajikman
mine was $50 and napa had to special order it, I am still trying to figure out if I should get high flow cats or find a used set of cats since I have my smog pump deleted, I don't want to mess up a pricey high flow cat x pipe if they are going to just get clogged up.
Old Aug 25, 2007 | 09:51 AM
stang8689's Avatar
stang8689
ditch the pully, remove all that crap and plug the holes in the back of the heads
Old Aug 25, 2007 | 12:48 PM
945LSTANG's Avatar
945LSTANG
you sure??
Old Aug 25, 2007 | 01:22 PM
grumpyphillips's Avatar
grumpyphillips
It you only deleted the smog pump then you will use an 84.5" short belt.
