Fuel Pump..........
Old Aug 29, 2007 | 07:55 PM
ncplaya88's Avatar
ncplaya88
Default Fuel Pump..........
Well I guess I'am just going to get a fuel pump. It just doesnt make any sense. 12.4 volts into the fuel pump relay and 6.1 out....(replaced relay).......Maybe a short to ground or something or the fuel pumps burnt up and causing a drain, I dunno. I dont hear the pump kick on, was driving the car and it just died. I attached a diagram with my voltage readings on them. Thanks for any help or ideas. (1992 Mustang GT)
[IMG]local://upfiles/53284/4BF371A776B74A3BB8383C976CEB204C.jpg[/IMG]
[IMG]local://upfiles/53284/63CC74112801490EAABDAC6473A6F887.jpg[/IMG]
Old Aug 29, 2007 | 07:57 PM
mattdel's Avatar
mattdel
Default RE: Fuel Pump..........
bad ground
Old Aug 29, 2007 | 07:59 PM
ncplaya88's Avatar
ncplaya88
Now that I think about it.........Could it be the PCM? Since it grounds the relay? There is a slight clicking noise coming from somewheres in the PCM's area........I dunno just putting some ideas out
Old Aug 29, 2007 | 08:11 PM
ncplaya88's Avatar
ncplaya88
Where would I found the ground to check it?
Old Aug 29, 2007 | 08:14 PM
mattdel's Avatar
mattdel
terminal # 86 on the relay is ground
Old Aug 29, 2007 | 08:42 PM
ncplaya88's Avatar
ncplaya88
now if that shows to be a bad ground..........then what? pcm?
Old Aug 29, 2007 | 08:43 PM
94StinkinLincoln's Avatar
94StinkinLincoln
if its not the wires, i have my stock pump, the sock filter on it is brown so im sure its got some miles on it. u can have it just pay shipping.
Old Aug 30, 2007 | 06:51 PM
ncplaya88's Avatar
ncplaya88
Where does the pump ground out at? Any other ideas?
Old Aug 30, 2007 | 09:32 PM
ddeaton66's Avatar
ddeaton66
bypass the relay for a check, relays do go bad.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
