Head Installation Advice Needed Please !
Old Feb 8, 2005 | 09:40 PM
Dan89lx's Avatar
Dan89lx
Default Head Installation Advice Needed Please !
I just bought a set of Edelbrock Performer Heads and roller rocker from my friend (stud mount). Could someone please reccomend which head gaskets to use, I am on a budget. Also could someone give some advice on how to adjust the rockers. I plan on buying stock length hardened pushrods and ARP bolts. Thanks In Advance.
Old Feb 8, 2005 | 09:50 PM
StangerGT's Avatar
StangerGT
Default RE: Head Installation Advice Needed Please !
i have heard good things about cometic gaskets, but i dont know how much they are. I hear that you just adjust the rockers till they dont click on the pushrods anymore and that is zero lash at tdc and tighten them there.
Old Feb 8, 2005 | 10:10 PM
sup95cobra's Avatar
sup95cobra
Quick ? Are you running a cam? If so what size is the vavles? If 2.02/1.6 I have you checked for piston to vavle clearance?
Old Feb 8, 2005 | 10:57 PM
Dan89lx's Avatar
Dan89lx
1.90/1.60 valves and I have an E303 cam (.498/.498)
Old Feb 8, 2005 | 10:58 PM
Dan89lx's Avatar
Dan89lx
i used cometic gaskets on my dirtbike, they worked well. Please explain what zero lash means, sorry but I dont know much about adjusting valves
Old Feb 8, 2005 | 11:15 PM
angcobra's Avatar
angcobra
ORIGINAL: Dan89lx
Lash is the term used to descripe the gap between the rocker arm and valve stem. Zero lash is no gap. On solid lift cams, you have to adjust a small gap between the rocker arm and valve stem when the piston is at TDC (no lift on cam for that valve). With hydraulic lifters, you adjust until you just reach no (zero) gap then you typically turn the nut 1/4 to 1/2 turn more (depending on application) to slightly depress lifter.
Old Feb 9, 2005 | 01:00 AM
Dan89lx's Avatar
Dan89lx
thanks- any other helpful hints anyone?
Old Feb 9, 2005 | 01:02 AM
fast83gt's Avatar
fast83gt
Edelbrock recomens felpro gaskets. I believe they are pretty much the standard.
Old Feb 9, 2005 | 01:07 AM
fast83gt's Avatar
fast83gt
Felpro part # FPP-1006
Old Feb 9, 2005 | 01:25 AM
Dan89lx's Avatar
Dan89lx
thanks man
