compression
I still can't figure out why my 95 gt is reving so slow and cant get out of its own way....[/align]I have replaced the :[/align]fuel filter[/align]cap[/align]rotor[/align]distributor[/align]wires[/align]coil[/align]took off injectors and cleaned them(going to get new ones or have the old onces professionally cleaned and balanced)[/align]checked fuel rail and fuel pump flow[/align]MAF is new already[/align]Checked CATs (took off mid pipe, looked clean, and ran open headers, car still couldn't get out of its own way)[/align][/align]my car still has white plugs...very lean....and i can't pin point y[/align][/align]anyways im doing a compression test tomorrow, and I want to know what is the correct compression in each cylinder that i should see on the compression gauge if a cylinder is healthy?[/align][/align]if anyone else has imput please let me know[/align][/align]*i am also throwing a check engine light that will come on while driving, stay on for a min or two, then go off. I have tried to have it scanned and no one can find the code in the history of the computer so i dont know what this code is...[/align]
sounds to me like you have a very bad vacuum leak. take some carb cleaner and spray around the hoses and lines if you do have one the rpms will spike a little. also spray around the intake and all
just re did the intake, since i had to take it off to get the fuel rail off. i replaced one line that looked a little old but thats it. the car idels and runs SMOOTH, not rough, it just has no ***** when you get on it because 3 out of the 4 plugs i pulled are whiter than a ghost, aka no fuel. when i tested my injectors they were "pissing" fuel instead of misting it so I think it might be them, also the car was driven 4k in the past 2 years....it sat alot and i dont think the guy ever took it over 2.5k rpm. i still want to know what the code it that i randomly throw and i want to do a compression test
check your wires again. i had a similar problem when i change my headers. the headers was melting my #3 and #5 wires. i had some arching going on. i put those taylor boot protectors around some new taylor ignition wires. also check your timing.
well i did check the timing....one of the first things and somehow the guy before me had it at 24*, i set that b*tch back to 14*. the wires are new, and im sure good, i have been over all of them while taking them on and off checking the plugs....finding them white and lean
for lack of a better comparision, mine were spraying like you **** when you go to the bathroom, they were one solid stream, and i only got that after i cleaned them bec some were not spraying at all at first...so i need new injectors?
uberstang1
Sep 20, 2015 06:42 PM
