Same old problem
Old Sep 4, 2007 | 08:03 PM
sn95red94gt's Avatar
sn95red94gt
Default Same old problem
I have a 94 gt, an have a strange puzzling problem. It will start fine some times an not others. It wouldnt start the other day so I had it towed to the local ford dealer an it started right up for them. I have replaced the coil, plugs, dist. cap and rotor, fuel filter. It still won't start some times, usually when it wont start I can pull a boot off of a plug put a plug in it an ground it an I don't get spark. Im puzzled so if you have any suggestions plz post em. thanx
Old Sep 4, 2007 | 08:04 PM
mattdel's Avatar
mattdel
Default RE: Same old problem
how many miles
Old Sep 4, 2007 | 08:08 PM
sn95red94gt
75,000 miles
Old Sep 4, 2007 | 08:10 PM
mattdel's Avatar
mattdel
its either gonna be the ignition module(TFI) or the pickup coil inside the distributor(PIP)
i'm leaning more towards the PIP.
Old Sep 4, 2007 | 08:16 PM
sn95red94gt
i forgot to add i also changed the icm but how does it act when the pickup coil goes out
Old Sep 4, 2007 | 08:18 PM
mattdel's Avatar
mattdel
no spark or injector pulse
Old Sep 4, 2007 | 08:26 PM
stang8689's Avatar
stang8689
my brother's car did same thing it was PIP like matt said
Old Sep 4, 2007 | 08:32 PM
sn95red94gt
injector pulse? no spark though.
Old Sep 5, 2007 | 12:03 PM
black89gt's Avatar
black89gt
mines did the same thing too. my problem was the starter.
Old Sep 6, 2007 | 06:37 PM
sn95red94gt
if the pickup coil is going out will they be able to pick up the code if it starts?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
