inside of car very hott
Old 09-06-2007, 05:35 PM
five0fm
five0fm's Avatar
Default inside of car very hott
whenever i drive the inside heats up a lot....the heat is completly off i was wondering if there is a reason for this?
five0fm is offline
Old 09-06-2007, 05:48 PM
mattdel
mattdel's Avatar
Default RE: inside of car very hott
blend door and/or heater control is probably stuck/bad
or the vacuum source is pinched/off
mattdel is offline
Old 09-06-2007, 06:09 PM
five0fm
five0fm's Avatar
it doesnt seem like its coming out of the vents though....more where the pedals are
five0fm is offline
Old 09-06-2007, 06:14 PM
ZachW04Stang
ZachW04Stang's Avatar
Do you have longtube headers? Some one might have taken your firewall insulation out before you bought the car and now heat is coming through.
ZachW04Stang is offline
mattdel
mattdel's Avatar
mmhmm... same thing. its all vents. the blend door decides where the heat goes.
mattdel is offline
Old 09-06-2007, 06:16 PM
five0fm
five0fm's Avatar
what is a blend door..and no i have shorties headers......
five0fm is offline
Old 09-06-2007, 10:44 PM
LCBlackDep183
LCBlackDep183's Avatar
open your windows. jk
No really what temp does your motor run at, your motor may just be running hot, does it have the stock t-stat and have you ever flushed the coolant system.
LCBlackDep183 is offline
Old 09-06-2007, 11:11 PM
BlackBetty93GT
BlackBetty93GT's Avatar
do you have an AOD...the produce a lot of heat, and will sometimes warm up the inside of the car
BlackBetty93GT is offline
Old 09-06-2007, 11:33 PM
r.barn
r.barn's Avatar
If your heater core has a small pin hole in it, it can release
steam into heating system even with heat turned off.
Are you getting water out of the heater core drain hole on the firewall?
or loosing coolant very slowly?
or leaking out of vents under glove box on to pasngr carpet?
all signs of bad heater core, including inside of car getting hot.
r.barn is offline
Old 09-06-2007, 11:55 PM
LS1this
LS1this's Avatar
do you have a stock or catted H pipe? It could be from the cats. If your car is running rich they may be getting too hot.
LS1this is offline
Quick Reply: inside of car very hott
