Heads
Old Feb 16, 2005 | 12:28 AM
91GTFox111's Avatar
91GTFox111
I ♥ Acer
Default Heads
What Heads go good with what Intakes ? i heard Gt40 intake dosent go good with AFR heads is that true?
Old Feb 16, 2005 | 12:58 AM
grabbem88's Avatar
grabbem88
Default RE: Heads
afr recomends victor series,and rpm intakes,but a gt40 would work if gasket matched.
Old Feb 16, 2005 | 03:10 AM
90LX50's Avatar
90LX50
Default RE: Heads
I'm thinking about the Victor Jr. heads, will my Profession Products intake work since it's a clone of the Edelbrock RPM intake?
Those heads look pretty sweet
Old Feb 16, 2005 | 08:08 AM
mustang_mike_2003's Avatar
mustang_mike_2003
Default RE: Heads
This post wont last long.. this question has endless answers and no one wants to respond by righting a book about head and inake matching... just my oppionion. To answer your question, id get a total power plater. lots of guys make them (edlebrock, ford racing, holly, ect) the power increaces are dyno proven so youll know what your geting with the up grade. not to mention the fact that you can sleep easy knowing that your not losing power because you tryed to cut corners and mix and match parts that dont work well together. The platers come with complet heads rockers and all, compatible cams, upper and lower intakes, exaust headers and even the upgraded fule injectors and pump your going to need with the additional power. If i didnt live in alaska, and i didnt need to drive my mustang in the winter snow, id get the edlebrock total power plater. its rated at 350hp and 350 tq. You can get it in a 50 state street leagle setup if emmisions are a concern, and whats cooler then upgrading your stock block to making that kind of power N/A?? and believe it or not, the total cost will be waaay cheaper then trying to buy it pice by pice. having all the stuff you need makes for one fun weekend with the friends, turning your motor from a sleepy 5.0 to a chevy crusher .. hope i helped
Old Feb 16, 2005 | 11:23 AM
90LX50's Avatar
90LX50
Default RE: Heads
ORIGINAL: mustang_mike_2003
That's all fine and good, but i don't have 2200.00 to blow, I have 2K, So I'll be getting what I can afford. That would be a set of heads, a cam, new ARP bolts and all gaskets along with a new timing set and lifters.
Thanks for the input tho.
Old Feb 18, 2005 | 03:30 AM
mustang_mike_2003
Default RE: Heads
theres plater kits for 1,500 bucks...that make over 350 hp..just look around man..they come with heads cam intake (upper and lower) and injectors
Old Feb 18, 2005 | 03:41 AM
91hatchgt's Avatar
91hatchgt
Default RE: Heads
Yeah that is all well and good until you want to put in a bigger cam or something, then guess what, all those parts that came in your platter are not doing what they were intended to do.. I would WAY recommend researching and buying piece by piece, much more efficient for making the kind of power or RPM range that YOU want.. It does take some researching though.
Old Feb 18, 2005 | 03:43 AM
nemethjames1's Avatar
nemethjames1
Default RE: Heads
any intake will work decent as long as it flows good, obviously a stock ho wont work very well.. a ported gt40 will work as good as an edle for sure
Old Feb 18, 2005 | 04:13 AM
Aliate X's Avatar
Aliate X
I ♥ Acer
Default RE: Heads
So the BBK intake wont work with AFR's???
Old Feb 18, 2005 | 04:16 AM
nemethjames1
Default RE: Heads
bs, the bbk would work sweet
