Distributor problems
Old Sep 27, 2007 | 09:25 PM
93bluestang's Avatar
93bluestang
Default Distributor problems
hi im a new member and i recently bought a 1988 mustang gt its has a little bit of work done to it, GT40 heads cobra intake E or B 303 cam im not sure it has a real rough idle, so the guy that built the motor said he kept the timing at 20 degrees advanced and i checked it today and it was at 0 so i figures i would go and advance it so i loosen the bolt that hold the color that keeps the distributor tight and i can not move the distributor at all its as if it is seezed it did sit outside for a while. What can i do to fix this it runs like crap with the timing set at 0. thanks!
Old Sep 27, 2007 | 09:38 PM
r.barn's Avatar
r.barn
Default RE: Distributor problems
Its common for them to stick if they have been turned in forever
Maybe spray some WD40 on there and let it set over nite
and keep gently but firmly trying to get it to move.
Remember to turn it with spout out, 10* BTDC with spout out is factroy setting
most people try and get it up to 14-16* spout out.
Old Sep 28, 2007 | 06:08 AM
93bluestang
alright im going to try that thanks a lot
Omgitsa88Stang
Oct 5, 2015 07:33 AM
StalkerGT
Sep 25, 2015 02:41 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
jaiidutch
Sep 14, 2015 10:29 AM
