E303 CAM And solid lifters
Old Sep 30, 2007 | 06:48 PM
93bluestang's Avatar
93bluestang
Default E303 CAM And solid lifters
i have a E303 cam in my car witch is more radical the E303 or B303? and whats the power band on the E303. My car also has solid lifters and they seem to be making noise. I know they need to be adjusted every so often it has 23,000 miles, it has 1:6 rockers on it how should i go about asjusting them?
Old Sep 30, 2007 | 09:03 PM
tinman's Avatar
tinman
Default RE: E303 CAM And solid lifters
Any of those cams that you post about desinged for Hyd. roller lifters.
NOT solids..........
Old Oct 1, 2007 | 05:17 PM
93bluestang
well then i gues the guy that built the motor is lieing to me.
Old Oct 1, 2007 | 05:58 PM
Maxwelhse's Avatar
Maxwelhse
Or they're Rhodes lifters or something... Or the guy is crazy and did it anyhow.
Old Oct 1, 2007 | 07:26 PM
mojopony's Avatar
mojopony
If you mean the Rhoads "variable duration" lifters, they're still hydraulic. They might tick like solids, but that's about it.
Old Oct 1, 2007 | 08:16 PM
LA95GT's Avatar
LA95GT
E cam is more " radical " but its a hydraulic
Old Oct 1, 2007 | 08:57 PM
And then some's Avatar
And then some
It's not an uncommon practice to use solid roller lifters on a hydrolic roller cam. The only time you would have any real issues is if you try to use hydrolic lifters on a solid roller cam. The best way to adjust them is to adjust one cylinder at a time, turn the engine over untill the exhaust valve starts to open. Then adjust the intake valve to about .010 with a feeler guage. turn the engine over untill the intake is almost closed and adjust the exhaust to about .012. You'll want to make the adjustments with the engine warmed up and you should be good to go.
Old Oct 1, 2007 | 09:18 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the e-cam has more lift but the b-cam has slightly more duration
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
