clutch problems
Old Oct 2, 2007 | 08:14 PM
bzlover's Avatar
bzlover
Default clutch problems
i have a question, i installed my clutch last night but something wasnt done right kuz i turned on my car and it sounded like my clutch was rubing against something.., anyways imma take it back dwn 2night and i wanted to know .., does the pressure plate have its own way of going in or just as long as the bolts line up..?
Old Oct 2, 2007 | 08:19 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: clutch problems
Before taking it all back apart, remove the inspection plate and see if there are any shinney spots (would indicate rubbing) anywhere.
Old Oct 2, 2007 | 08:20 PM
holyshift's Avatar
holyshift
I had that problem once when i installed my Spec Billet Steel flywheel, it rubbed on the block plate but the noise went away after the car ran for like 5 minutes, never messed anything up
Old Oct 2, 2007 | 08:31 PM
bzlover's Avatar
bzlover
my flywheel isnt new just machined.., i have a feeling i put the disc on wrong but if i did wouldnt the pressure plate not bolt down all the way..?
Old Oct 2, 2007 | 08:34 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Correct, it would not go on.
Old Oct 2, 2007 | 11:04 PM
bzlover's Avatar
bzlover
well i have everything down and i c no remains of metal pieces (grinding) what else could of caused the noise when i started car..., the other thing i was thinkin of was that i didnt center the throw out bearing right but doesnt the input shatf on the tranny line it up when i put it back on..? im desperate....!
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
