engine temp problem
Old Oct 14, 2007 | 11:22 PM
FoxGT's Avatar
FoxGT
Default engine temp problem
I'm really not understanding what's going on here. The car had a 180 degree tstat in it. During first warmup it goes up to around 230 degrees then jumps down to 180 degrees& stays for a while, then starts climbing again & drops. Replaced the tstat witha 185 degree & still doing the same thing. water pump was just replaced.
It does this while idling or driving, will climb up to around 220-230 then drop to 180 pretty quickly
At first I thought low coolant because the car didn't seem to take that much before it was all the way full so I would let the engine run, pour some in, let it run a bit, pour some in, let it run , then pour some in. Always does the same thing.
Any idea what could be causing this?
I do know it does need a flush pretty bad, every time I drain the coolant it comes out rusty looking, like brownish tint to it.
Old Oct 15, 2007 | 03:20 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: engine temp problem
Possibly have an air pocket. Are you getting good circulation through the radiator? You should be able to see flow w/ the cap off and the car running
Old Oct 15, 2007 | 07:49 AM
turt's Avatar
turt
After work is done on the cooling system that is a normal thing to happen due to air in the system. If this continues anfter a day or two of driving and refilling the system to proper level then you may have a problem. It sounds like the thermostat is doing its job. The temp will get around 200 with a 185 stat before it drops. If you feel like the temp is getting too high before it drops AND you already tried another T-stat with the same results, then maybe your gauge is inacurate. This could be caused by a bad sending unit, gauge, or voltage regulator in cluster. Start with the eaisiest (sender) and go from there. From the way I took your post it seems like when the stat opens the car does go back to 185ish. If, while driving for a while the car continues to raise in temp then it is an engine fault which could be a list of things.
Old Oct 17, 2007 | 08:28 PM
FoxGT's Avatar
FoxGT
i'm 100% positive the aftermarket gauge is correct.
I'm pretty sure it is air pockets. Everytime I look the coolant is low & needs more.There are no leaks for coolant to get out of either.
I'll give it a try this weekend. It's been in the shed, just got the gears swapped & already started takingthe engine out & apart. (low oil psi replacing the crank,rod, main, cam bearings) should be done by friday
Old Oct 17, 2007 | 09:18 PM
AdderMk2's Avatar
AdderMk2
Banned
park the car facing up a hill with the rad cap off... any bubbles in the system will work their way to the highest point in the system
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Spiral534
Oct 6, 2015 04:31 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
