egr question???????
yeah, remove it and buy a block off plate and I believe there is a way to disable the parameters in the eck...there is the ole resistor trio trick...just do a search on here for that and can't exactly remember the other one..someone else may know on this better than I
Ya what you do is pull the lower intake off. block off the egr whole there with jb weld,buy a block off plate where the egr was then buy a some kind of resiseter?? to plug itno the harness do a search you will find it.But all in all you gain ZERO hp from doing this and most just pull it off and slap a plate on there but hot gas will still travel from the lower intake to the upper NO matter what unless you pull it off and block it.Its a waste of time and money unless done right then you migh get like 1/2 hp gain from this.....
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
