How do you take the windsheild trim off a foxbody
Old Oct 25, 2007 | 07:10 PM
ryan_89_mustang's Avatar
ryan_89_mustang
Default How do you take the windsheild trim off a foxbody
I need to get the window trim off to fix a leak how does it snap off? thanks in advance
Old Oct 25, 2007 | 07:24 PM
adumb's Avatar
adumb
Default RE: How do you take the window trim off a foxbody
are you talking about the plastic piece on the outside going along the door into the rear view mirror? if so when you open your door look on the inside of the jam uptop you will see a single screw. take that out and then it will slide in the direction away from the mirror.
Old Oct 25, 2007 | 07:44 PM
ryan_89_mustang
I meant to say WINDSHEILD sorry for the confusion
Old Oct 25, 2007 | 07:47 PM
Boss_Hotrod's Avatar
Boss_Hotrod
You need a little hook tool to pry little clips away from the trim. You can get one at Napa.
Heres what it looks like.
mattdel's Avatar
mattdel
pay to have it done.
unless you are a trained window installer you are going to make it worse.
Old Oct 25, 2007 | 08:04 PM
5ohcasey's Avatar
5ohcasey
pull the trim away from the metal edge to load the springy part of the clip then lift up on the glass side of the trim and it should pop out I had to use a dash/trim prybar with a rag on the glass and gently pry to get the first clip started then it went pretty smooth.
Old Oct 25, 2007 | 08:07 PM
ryan_89_mustang
ORIGINAL: mattdel
How much could It cost to to have done?
b8checker
Oct 8, 2015 12:55 PM
mdg
Oct 1, 2015 07:04 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 16, 2015 07:53 PM
mdj89
Sep 8, 2015 10:40 PM
