how to tell what size injectors are
Old Oct 26, 2007 | 06:25 PM
five0fm's Avatar
five0fm
Default how to tell what size injectors are
i have some injectors i just found and i need to know how to tell what size they are
Old Oct 26, 2007 | 06:56 PM
5ohcasey's Avatar
5ohcasey
Default RE: how to tell what size injectors are
Theres also lots of other handy info in the tech articles section just up above where these posts show..
Heres the link to the injectors page. hope it helps
https://mustangforums.com/m_967788/tm.htm
Old Oct 26, 2007 | 06:58 PM
five0fm's Avatar
five0fm
yeah i checked that out but the injectors are new they arent from another car. thanks though
Old Oct 26, 2007 | 07:04 PM
5ohcasey's Avatar
5ohcasey
Wellll are they from a ford? any numbers on them? gots a pic of one?
Old Oct 26, 2007 | 07:06 PM
five0fm's Avatar
five0fm
there lucas/delphi with a blue ring around the top side says 2084 and 01D030B
Old Oct 26, 2007 | 07:11 PM
5ohcasey's Avatar
5ohcasey
http://www.injectorservices.com/Flow...x/l01d030b.jpg Is this it?
Old Oct 26, 2007 | 07:37 PM
five0fm's Avatar
five0fm
yeah those are it but blue ring
Old Oct 27, 2007 | 08:50 AM
stang8689's Avatar
stang8689
sounds like 24#
Old Oct 27, 2007 | 09:26 AM
Richter12x2's Avatar
Richter12x2
The blue ring instead of a green ring is nothing, that's just an o-ring, if the numbers match then they should flow the same. The quick and dirty conversion method is to drop the zero and you'll be in the ballpark - if those are 440cc/m injectors, then they're in the neighborhood of 44#, most likely 42#, because that seems to be a common rate of flow.
mltdwn12
Sep 23, 2015 08:54 AM
Demodulates
Sep 18, 2015 11:14 AM
pimp2303
Sep 17, 2015 08:45 PM
uedlose
Sep 10, 2015 01:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
