ah! help.
Old Oct 27, 2007 | 11:47 PM
5.0L RiCE EATER's Avatar
5.0L RiCE EATER
Default ah! help.
I wake up and go out to start my car, won't start. Batteries dead and the battery was just put in like 2 weeks ago. Figure maybe the alternator is bad because the car won't charge when its running, so I change the alternator car ran fine for about a week. Only put out about 9 volts at idle and when on the gas put out about 11 1/2 or 12 volts. I'm inside red robins and go out to start the car again and click click click, wouldn't start. Anybody have any input?A short somewhere maybe?Alternator was a lemon?
Old Oct 27, 2007 | 11:59 PM
aode08's Avatar
aode08
Default RE: ah! help.
wiggle the ground wire and listen real good.
aode08's Avatar
aode08
ALSO CHECK THE SUNVISOR LIGHTS
Old Oct 28, 2007 | 07:04 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 5.0L RiCE EATER
If the alt only putting out 12 volts, something is wrong. It should be putting out around 14 v @idle. Either the alt is bad or there is a wiring problem.
Old Oct 28, 2007 | 11:58 AM
ddeaton66's Avatar
ddeaton66
What Pro said ^
Old Oct 28, 2007 | 02:02 PM
5.0L RiCE EATER
A buddy of mine told me the battery should have been recharged using a charger when the alternator was put on? And that could be causing the alternator to only put out low volts
Old Oct 28, 2007 | 02:12 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I have seen a bad battery cause it, but it's rare. How old is the battery. Here's a lil test for ya. Start the car, disconnect the neg side of the battery. If the alt is working, the car will stay running. If not, the car will shut off. I'm still betting on the alt or a wiring problem.
Old Oct 28, 2007 | 02:43 PM
5.0L RiCE EATER
Battery is only around a month old
Old Oct 28, 2007 | 05:10 PM
ddeaton66's Avatar
ddeaton66
I have seen that ole trick fail ya too, if olny a couple diodes are out it may still put out enough to run the essentials (ecu, fp, sensors) but not nearly enough to also charge the battery, run the heat, a/c lights etc......if you have any doubt take it to one of the national chain auto parts stores and have them load test the alternator... .
jm2c
Old Oct 28, 2007 | 06:10 PM
roghoge's Avatar
roghoge
try checking the negative connection to the battery...mine was doing the same thing...the guy we bought it from put in a new batter but he didnt have the connection tight enough and it wasnt really connected so it would come loose after driving it or after just trying to move it...but not loose to the point where you could see it was loose, so you might just want to try tightening it
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
mustangheaven
Sep 29, 2015 11:00 AM
