damn rust
Old Oct 28, 2007 | 09:49 PM
Stroked91's Avatar
Stroked91
Default damn rust
so im in the process of rebuilding a rear for my 91 gt and discovered rust on the inside of the axle tubes. so does anyone have any idea on how to get it out other than hot tanking due to the fact i cant find a place that does it. im gonna try sand blasting but was tryin to see if there was some sort of rust remove i could use
Old Oct 28, 2007 | 09:54 PM
aode08's Avatar
aode08
Default RE: damn rust
dont touch it.
Old Oct 28, 2007 | 10:01 PM
Stroked91's Avatar
Stroked91
every pick i took it wouldnt come out clear
Old Oct 28, 2007 | 11:00 PM
greenstreak9205's Avatar
greenstreak9205
did it get the rust in there while it was in the car or was it sitting around?
Old Oct 29, 2007 | 09:30 AM
Stroked91's Avatar
Stroked91
the rear was sitting around
Old Oct 29, 2007 | 03:05 PM
greenstreak9205
i would think that you could take one of those rabbit turd hones thats the size of the axle tube and get in there all nice like. unless its way in there then just sand blast it if you can. just my .02
Old Oct 29, 2007 | 03:21 PM
kweb288's Avatar
kweb288
ORIGINAL: greenstreak9205
but you need to make sure that all the grim gets out before you put it together, other wise it will sign the death of your rear end/parts
Old Oct 29, 2007 | 03:32 PM
Stroked91's Avatar
Stroked91
i had to clean it all down before i sent it out then i gotta clean it all down when the guy is done
Old Oct 29, 2007 | 04:01 PM
greenstreak9205
brake clean, a few red shop rags, something long enough to shove it through and some compressed air always worked for me
Old Oct 29, 2007 | 04:13 PM
Stroked91's Avatar
Stroked91
brake clean is the **** but dont get it in your eyes[:@] opps
