Cementing Block
They make a block filler that you do it with. The only advantage is you do make the block substantially stronger, and in racing applications it is somewhat common, you reduce cooling efficiency though.
ORIGINAL: stanguy306
Hey guys, what constitutes "cementing" a block? Is it a big advantage or? Thanks
Im going to go with a main and valley girdle....I'm going to pushing the envelope on a stock block just wondering if I should go dart block.....but thats a major price diff. sux.....but its the man way to do it...haha
does the sportsman actually hold anymore? and i would like to see someone run a stock block with the valley and main girdle i think that would drastically strengthen the stock block by not allowing the top of the cylinders to flex so it wouldnt split down the middle. anyone running the two girdles and having good luck? i might try it who knows
302's split from the botto up ...not going to make much a difference.......people half fill 302 when they do 347's to help the distortionat the bottom of the cylinders.....wouldnt recommend it on a street car...tends to over heat......
