Question concerning my engine
Old Oct 30, 2007 | 04:59 PM
RawGtPower's Avatar
RawGtPower
Default Question concerning my engine
Ive noticed that everytime i drive for a while, and pop my hood, my oil dipstick is popped out a few inches. I dont believe im getting blow by, my rings are a year old, along with my whole engine. besides that, it was doing the same thing with my old engine, is there anything else that may be causing this pressure build up in my crank case
Old Oct 30, 2007 | 05:10 PM
Ninety5five0's Avatar
Ninety5five0
Default RE: Question concerning my engine
Pcv valve is the only other thing i can think of.......
Is your screen clean ?
Old Oct 30, 2007 | 05:33 PM
ahittz24's Avatar
ahittz24
you PCV system is not fuctioning properly. Make sure all of thehoses are hooked up correctly.
RawGtPower's Avatar
RawGtPower
i just went out there and noticed that the pcv hose is covered in oil.
Old Oct 30, 2007 | 05:34 PM
67mustang302's Avatar
67mustang302
You ARE getting blow by. All engines get some amount of blowby, the only way you have a 100% seal is if you weld the piston to the cylinder wall. Put a pcv system on it, that's what it's for, to evacuate crankcase pressure that's caused by blowby
Old Oct 30, 2007 | 05:44 PM
RawGtPower's Avatar
RawGtPower
there is a crankcase ventilation system on it. I pulled the pcv and noticed oil around the inside. i also believe that its missing the screen, shout the screen be pretty obvious its there because i pulled the valve and stuck my finger down and didnt feel a screen, or feel anything move around.
Old Oct 30, 2007 | 05:49 PM
RawGtPower's Avatar
RawGtPower
isnt there only the one hose that relates to the pcv. The one that goes from the valve to the intake? The hose is on correctly. There must be too much pressure in my crank case to be blowing oil through the pcv valve
Old Oct 30, 2007 | 06:57 PM
cleanfitty's Avatar
cleanfitty
You'd feel the screen if you stuck your finger down there, so lets assume it is missing, that shouln't cause any problems... unless it is thereto block any oil from getting into the PCV system and pluging it up... ??? Installing the screen is real simple, removing it can be a small PITA,but I would install a screen and a new valve and see what happens.
Old Oct 30, 2007 | 07:01 PM
mpolarisf's Avatar
mpolarisf
removed my intake last week OIL all in it like caked inside of it
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
