step by step guide...lifters
Old Mar 2, 2005 | 07:42 PM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
Default step by step guide...lifters
Ok, Im going to be replacing a few of the driver side lifters. Can anone tell me how to get this job done, What do you start with first, Any special tool required, the process, on replacing them.
Old Mar 2, 2005 | 08:49 PM
69mach1377's Avatar
69mach1377
Default RE: step by step guide...lifters
Step 1;
Remove intake manifold
Step 2;
to be provided by next responder...
Old Mar 2, 2005 | 11:07 PM
roundman's Avatar
roundman
step 1- go to auto parts store and buy a Ford high pressure fuel line disconnect tool so you can break the connections on the fuel lines so you can remove the lower intake manifold
step 2 - get a Haynes manual on the small block Ford while you're at the auto parts store and read the section on removing the intake manifold.
Old Mar 2, 2005 | 11:12 PM
Justin_Bradley's Avatar
Justin_Bradley
Are "lifters" and "pushrods" one in the same?
Old Mar 2, 2005 | 11:40 PM
90Mustangfan
I ♥ Acer
I have the factory ford manual, which is way better than the haynes. but still it doesnt say if there are any special tools needed to do this.
Old Mar 3, 2005 | 04:07 PM
roundman's Avatar
roundman
ORIGINAL: Justin_Bradley
NO- the lifters ride on the lobes of the camshaft and the pushrods ride in the top of the lifter and transfer the up/down motion of the lifters to the rocker arms which in turn open/close the valves as directed by the lobes on the cam.
Trust me on this one, you will need the special tool available at most decent auto parts stores to break the special high pressure connections on the Ford fuel lines before you can remove the lower intake manifold. they are two different sizes of lines and a tool for both sizes made of hard plastic is available for under $20 at most places.
Old Mar 3, 2005 | 04:14 PM
91hatchgt's Avatar
91hatchgt
I was able to remove and install my new intake manifold without taking out the fuel lines. It is tight, but I had no problems.
FivePointToTheOh
Mar 9, 2020 10:26 PM
firehorse02
Nov 16, 2015 11:28 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:58 PM
TfcCDR
Sep 14, 2015 12:08 PM
