stalling only on startup
I've got a 93 notch and on cold starts, the car stalls 3-5 times before the engine stays running. the rpms just drop and it cuts out. The car has never stalled during a drive and starts up perfectly even a few hours after it has been out. this only happens on initial cold start ups. any ideas as to what this may be?
depends on how cold it is outside where your at..if temps have reached near or close to freezing...ford put out a tsb on the IAC motor and moisture freezing the pintle so that it would not operate or un stick itself until a little engine heat dethawed it....or it could simply be carboned up and need cleaning
Its not due to cold weather. I don't know what it is, but my sn95 does the same. It starts and bogs and dies and starts just fine after that. and then it won't do it until the next morning.
ORIGINAL: PRO50SC
Could be a few things. Weak fuel pump, ect sensor, dirty IAC and or throttle body just to name a few.
I used to have the same problem and after I changed out my pump, it completely went away. Definitely a point to consider.
ORIGINAL: HotpodStang
trashxtrash
Sep 20, 2015 10:49 PM
